AndrewMayes
Jan 07, 2016Aspirant
Folders and files out of sync [RN104]
I purchased a ReadyNAS 104 a couple of months ago and have been using it without much of an issue, however I recently noticed something quite strange. When copying certain files and folders to the NA...
- Jan 12, 2016
I have found a solution to this problem, by logging into the admin page, then going to shares>settings>file access>reset and clicking the 'reset permissions' button and then resetting the file permissions to the previous setting. This seems to sort out the issues I was having with it. The underlying problem that caused this however has not been fixed, I had 'folder owner' checked for read/write access as well as the actual share owner for good measure which now works after resetting the permissions but seemed to be causing issues before. I suspect the file permissions got improperly applied, translated or corrupted when using one of the ReadyCLOUD remote clients.
AndrewMayes
Jan 12, 2016Aspirant
- BrianL2Jan 12, 2016NETGEAR Employee Retired
Hi AndrewMayes,
Which option is selected as the Folder Owner/Group? If you will set it to Guest and try to upload some files. Is there any difference?
Kind regards,
BrianL
NETGEAR Community Team
