msg4343
Feb 27, 2020Aspirant
Google Drive Sync Malfunction
Hi, I have a ReadyNAS 426 and I tried to configure Google Drive sync and it seemed to work fine. I could see the folders in my Google Drive cloud account so I know the username and password ...
msg4343
I should note I have tried in Chrome and Edge with no improvement.
JohnCM_S
Feb 27, 2020NETGEAR Employee Retired
Hi msg4343,
Have you tried leaving then rejoining to Google Drive?
May I know also the sync direction you selected on the NAS?
You can also download the NAS system logs then check google-drive.log. You might be able to find some clues about the issue.
- msg4343Mar 01, 2020Aspirant
Thanks for your response. When you say "Have you tried leaving then rejoining to Google Drive?", where would I do that? It seems that when I switch the Google drive option on in ReadyNAS it immediately throws an error so there is nowhere to "leave" and "rejoin"?
I have tried various local paths, cloud storage paths and both "bidirectional" and "Download cloud storage changes only" but all have the same errors. Attached is the google drive log.
Thanks again for your help!
Matt- JohnCM_SMar 03, 2020NETGEAR Employee Retired
Hi msg4343,
May I know the current firmware of the NAS?
Can you also provide the complete system logs? You may upload it to a file-sharing site then send me the download link via private message.
- msg4343Mar 03, 2020Aspirant
How do I send a private message?
