pratheepan
Feb 05, 2020Follower
Synching google shared drive with ready Nas
I am trying to synch ReadyNas 314 (Firmware 6.10.2) folder with google shared drive (shared by few members of the organisation). The pupose is to make onsite members and offsite members to work on same files at different time zones. we wanted the files that a ueser work on is uptodate and readily available for the user starts the work on next day from an other timezone. When I enable google cloud sync, the shared drives are not visible on the Cloudstorage path. Its always shows the "my drive" but not the shared drive. I have manager access to the shared drive in google.
We prefer google drive sync instead of giving access via Readycloud app as it's not fast enough given the connectivity restrictions to our premisces.
Is there a solution for the above? Appreciate your help.
Welcome to the Community!
Google Drive or Gsuite is a supported service on the ReadyNAS system but unfortunately, Team drives or Shared drvies are not yet supported. It would be best if you can add your Kudo on this Idea post so the engineers can check it and implement it if enough Kudos are seen,
https://community.netgear.com/t5/ReadyNAS-Idea-Exchange/ReadyNas-104-and-Google-Suite/idi-p/1538507
HTH
Regards
1 Reply
- Marc_VNETGEAR Employee Retired
HTH
Regards
