igl00
Jul 29, 2015Aspirant
Hiding share from ReadyCloud?
Hi, I have ReadyCLOUD working perfectly on my RN104 but I'm wondering if it's possible to hide some shares or folders from the cloud, as in only being able to access them from LAN (Windows 8.1), whil...
- Jul 29, 2015Are you trying to hide the folder/share from the invited user? Or are you trying to hide it from your (owner?) account?
If it is an invited user then Vandermerwe and JennC has the article posts that you are looking for to correct the behavior.
If you are referring to your account with the owner account, then there is not an option to allow you to hide the shares. Since you are the owner, you are considered the admin that will have more visibility than your invited users.
JennC
Jul 29, 2015NETGEAR Employee Retired
Hello igl00,
You may follow steps from this article ReadyCloud access right for a shared folder
Hope this helps and we look forward to your update.
