tomiaurednik
Oct 05, 2016Tutor
how to add cluod user to shered home folder
Hi, NAS 104, fw: 6.5.2 or 6.5.1 bouth versions works the some 1. How to access to linux console at NAS? 2. I have NAS user, name user1, and now I create readycloud user, aslo name: user1...
Sandshark
Oct 09, 2016Sensei
JennC wrote:
ReadyCloud users and local users get their own home share. These home shares are only accessible by the owner and the admin, they cannot be shared.
Yes, with this sad state of affairs, you are better off not using home shares. Instead, create folders yourself and give access to the local and ReadyCloud users. BTW, you cannot create a folder manually that has the same name as a user, and you aren't supposed to be able to create a local and ReadyCloud user with the same name (though it seems you have).
Other pluses of doing this are that you can use RSYNC for backup, where you cannot with home shares, and the file useage shows up on the Shares tab. Disadvantage, especially if you have a lot of users, is the extra work required.
