pzh20
Aug 12, 2016Star
How to move the ReadyCloud folder
I have set up Readycloud, but the ReadyCloud folder is placed on my C: drive and I want it on my D: drive, how to do I change its location? Regards Pete
- Aug 16, 2016
Hi pzh20,
No. It cannot be moved at the moment. I will give Kudos to the suggestion that you posted.
Kind regards,
BrianL
NETGEAR Community Team
pzh20
Aug 16, 2016Star
Are you suggesting that it cannot be moved?
I have sent an Idea to the forum you suggested.
Regards
Pete
BrianL2
Aug 16, 2016NETGEAR Employee Retired
Hi pzh20,
Kind regards,
BrianL
