Klayson1
Apr 29, 2015Aspirant
How to permanently disable ReadyCLOUD?
I just upgraded an RN516 from 6.1.8 to 6.2.2 and the IT department locked the unit off the network. When I attempt to download the RAIDar version 6.0 https://readycloud.netgear.com/client/install/RAI...
Apr 29, 2015Guru - Experienced User
RAIDar runs on a PC and downloads directly to the PC, so I am confused on how the NAS is on the download connection path.
You might check with your IT folks directly.
