Klayson1
Apr 29, 2015Aspirant
How to permanently disable ReadyCLOUD?
I just upgraded an RN516 from 6.1.8 to 6.2.2 and the IT department locked the unit off the network. When I attempt to download the RAIDar version 6.0 https://readycloud.netgear.com/client/install/RAI...
Nhellie
Apr 29, 2015Virtuoso
on Cloud>ReadyNAS Remote and ReadyCloud make sure both are switched off. Remote and Cloud uses port 6300, so might as well block any outbound connection using port 6300.
