Mr404notfound
Dec 27, 2015Aspirant
I can't exceed 2mb/s NG 102.
Bonjour,
Voila, je possede un Net Gear 102 et je dois faire un backup de mon pc. Le fichier etant compresser, je le transfert vers le Nas, mais impossible de depasser les 2mb/s. Mon probleme etant que mon fichier fait 150go. Merci de votre aide. :smileyhappy:
Ps: Ma box me sert de routeur et tout les ports y compris le Nas sont regler à 100mb/s
Hi,
Ihave a probleme with my Net Gear 102 and i must do a bckup of my computer. I have a big file to move in the Nas (150go), but i can't exceed 2mb/s.
Thanks for your help :smileyhappy:
Ps: My box serves as my router and all the ports including the Nas are adjust to 100mb/s
What firmware is running on the NAS?
Is the AntiVirus service turned on? If so, try turning it off.
@Google Translate wrote:
Qu'est-ce firmware est en cours d'exécution sur le NAS?
Est le service AntiVirus allumé? Si oui, essayez de le désactiver.
- Mr404notfoundAspirant
Appy New year,
Sorry for the late (and my english :smileywink: ),
i turn off the antivirus, but it have no effect, and i have no update for the firmware :smileysad:
Mr404notfound wrote:
Appy New year,
What firmware does RAIDar 6 say you are running?
