olje
Dec 23, 2015Aspirant
Issue with turning backup on after having stopped and deleted the backup.
I have an issue with the backup I want to do, but does not work.
I triggered a backup of the C:/users from the PC to the NAS314. It all looked OK at first. Then I made the appdata folder visible and the backup was not updated with this folder.
I then stopped the backup and deleted it and reinitiated a new backup for the same folder. Nothing happens except for indexing for 24 hrs. No files in the automatically generated folder on the NAS. Totally empty.
I have been able to replicate the issue for another folder as well after stopping, deleting nad reinitiating a new backup.
All firmwares up-to-date as well as the ReadyCloud app/client.
I may have to return to using Memeo as the backup software to feed the NAS and then use the replicate function to replicate the whole NAS externally to another ReadyNAS.
Any other ideas on how to fix this issue?
The NAS is a ReadyNAS 31400 with 4 4TB drives.
Best Regards,
- JennCNETGEAR Employee Retired
Backing up hidden folders in c:\users via NAS backup jobs is tricky, there are files in there that are locked down (and others that usually open).
If you have another PC, you can try copying AppData to a temp directory on it as a test.
- oljeAspirant
I have done the update to the beta software, but still the same problem. I have deleted the backups and re-initiated them again. Just indexing is being performed. For some of them after re-initiating they say that the backup is complete with a green checkmark, however, no files are in the backup folder.
If I create a new backup with a folder I have not backed up before it works, until I remove the backup and then reinitiate. Then I have the same problem again. Either indexing forever, or no files in the folder in spite of a green check-mark for a completed backup.
There seem to be some serious bugs in the backup function in the Readycloud App, so I will for now use the Memeo Backup software for these backups.
I hope it is not the same issue when replicating from one ReadyNAS to the other, since I am trying to create a off-site copy of the NAS I have centrally....
Best Regards,
Ola
