theotherwhitema
Jul 05, 2015Aspirant
media not showing up properly on Fire TV or Windows 8.1
When I access my RN104 on readycloud all of the movies and music I've added show up properly. However, when I try to do the same in File Explorer in Windows 8.1 two of the seven movies I've added so ...
Jul 05, 2015Guru - Experienced User
I've never used Kodi, but the issues you are describing there sounds like either a tagging problem or a naming problem.
On the multiple windows machines - are you saying that some movies are visible from machine A but not machine B? Or that some movies you uploaded can't be found at all.
