theotherwhitema
Jul 05, 2015Aspirant
media not showing up properly on Fire TV or Windows 8.1
When I access my RN104 on readycloud all of the movies and music I've added show up properly. However, when I try to do the same in File Explorer in Windows 8.1 two of the seven movies I've added so ...
theotherwhitema
In messing around a bit with Kodi, I have determined that the problem of files not showing up properly is related to upnp connectivity. When I connect via smb, everything shows up fine. Is there an advantage to using upnp over smb? If so, do I need to install Ready DLNA to use upnp?
I haven't installed ReadyDLNA or Plex (or anything really). I am running version 6.2.4 of the firmware and assumed that upnp was built in.
