ooooo
Jun 11, 2018Aspirant
MyNETGEAR erroneously indicating that product is already registered
Hi
- I logged into MyNETGEAR. I got a first message that says "No products registered under your profile".
- I tried to register my brand new RN202 for which I provided the serial number and purc...
Marc_V
Jun 11, 2018NETGEAR Employee Retired
Hi ooooo
It might not appear on MyNETGEAR but it seems it's already registered to your profile.
I would suggest contacting NETGEAR to verify this. I have sent you a PM.
Regards
- oooooJun 11, 2018Aspirant
Thanks Marc_V.
Does anyone know what's the best way to contact NETGEAR on this? Yesyerday I called the only number I was able to find on their website, "Premium" Technical Support. After over 100 minutes on the phone, I gave up since none of the three reps I talked to was able to solve the problem.
Thanks.
