brianraus
Oct 10, 2021Tutor
NAS 212 Keeps Dropping Connection (Switches Cloud to "Off" on Admin Page)
 Hi all.     I don't post much to forums anywhere, so please forgive any faux pas...     Basically what the subject line says.  I have a ton of media storage on my system and use Plex.  This wasn't a ...
- Oct 15, 2021
brianraus wrote:
I know that if I type in "https://nas-ip-address/admin" the browser changes to (Not secure) "nas-ip-address/admin". So even if I open up a Chrome browser and type in exactly what you have above, it is the same as if I opened up the ReadyCloud and clicked on the link after it tells me I have to be on the LAN. For me there seems to be no difference whether I type in the "https://" portion or not.
Public websites all use certificates issued by a certificate authority (CA). The CA certifies that the website is actually run by the company it appears to be run by. It also can be used to verify that there isn't a proxy between you and the website that is eavesdropping on browsing.
The NAS uses a self-signed certificate, so there is no way the browser can verify all this stuff. Still HTTPS will give you an encrypted connection (unlike HTTP). But most browsers now will try HTTPS first even if you type in HTTP.
In any event, you will need to click-through the browser security warnings when you log into the web ui.
One thing to check is whether the browser has your NAS admin credential saved. If it has an old password, then you can end up on the password reset page (because NAS is rejecting the wrong password). One test is to open an incognito window in Chrome, and use that to browse to https://nas-ip-address/admin. Or just go into your browser settings, and see if there is a credential for the NAS.
Oct 15, 2021Guru - Experienced User
brianraus
Oct 22, 2021Tutor
Sorry for the delay in responding.
I checked out some Plex community boards and such and changed some settings that were suggested. My NAS is running a lot better now. Taking your advice, I've linked a external drive to my NAS and I am now using the Backup tab (in admin settings) to backup what I feel is necessary at this time.
Again, I appreciate your knowledge and responses. I've only had the "Cloud" tab reset to "off" one time since I last posted here. Between your advice Plex boards, I'm in a whole lot better shape than I was. It used to happen at least daily.
Thanks again.
Brian
