tomiaurednik
Feb 03, 2016Tutor
NAS Rn104, ready cloud user problem, static IP problem, no NAS device found
NAS 104, FW 6.4.1 First problem: readycloud and other updates doesn't work if I set static IP on NAS? Why? Second: What should I do, if I'm not able to see NAS device in win explorer network?...
Feb 03, 2016Guru - Experienced User
tomiaurednik wrote:
NAS 104, FW 6.4.1
Usually this a user configuration error. Check the DNS server settings on the NAS first - most of the time users forget to set them up at all.
If the DNS servers are correct, then check the gateway address and subnet mask.
tomiaurednik wrote:
Second: What should I do, if I'm not able to see NAS device in win explorer network? I tried refresh, network is private, and I can ping my device. I can access to device thru web browser? Any idea how to solve this. Otherwise I don't know how to map network drive for home shares? Because until firs check-in home directory(dir) for invited user is not created.
Try running cmd, and entering the following:
net use * /delete
net use t: \\nasipaddress\username /user:username userpassword
The second command should map your home share to drive letter t. Be careful on the slashes. nasipaddress, username, and userpassword are of course all placeholders...
- tomiaurednikFeb 04, 2016Tutor
static IP works now (I didn't write DNSs.)
With old user I can't connect to Public or his dir. I get password error. (System error 86 has occurred.) But with the some un and pw I can connect to readycloud. But it is true that occurs this page: currently you don’t have registered or shred devices. And I can’t registered ? Why
(PS: in the past on NAS was created local user with different un, but use some email, but I delete it)
Any help will be appreciated.
