Chauser
Jul 14, 2021Aspirant
Netgear RR4360S FW 6.10.4 Apache2 Constantly fails. System more sluggish than usual.
Netgear RR4360S FW 6.10.4 Apache2 Constantly fails. System more sluggish than usual. Apache2 contniues to loop into safe-mode. Root Squash was stomping on shares, mistakenly tried to chmod the share,...
- Jul 28, 2021
Thanks,
I was able to fix my system by killing smb and nfs, and turning off the machines that had an iscsi connection. This allowed the apache to stablize in safe mode and for me to reload the firmware. The install was successful, but it still did not restart on its own; I still had to force it off about an hour of waiting.
Jul 14, 2021Guru - Experienced User
There is a hotfix for this problem. If it hasn't been installed yet, then reboot the NAS.
Chauser
Where is the hotfix located? I do blieve though that the upgrade process was interrupted, and a reload from flash may be required.
- mdgmJul 14, 2021Virtuoso
Sounds like you have SSH enabled. You can do e.g.
# dpkg -l | grep readynasos ii readynasos 6.10.5+1 amd64 ReadyNASOS base system
See the +1. If you see that that would indicate you have hotfix 1 installed.
Though my understanding is that the hot-fix fixes a problem with the management service (readynasd). apache2 going into safe mode is usually related to an issue with the apache configuration for an app.
- ChauserJul 15, 2021Aspirant
Thanks, I am not running the hotfix, however, I have no web access to update; Are there instructions on updating/repairing from ssh, instead of using the blind, power-button method?
Is there a method to backup the configuration via cli?
- SandsharkJul 15, 2021Sensei
Unless you disabled hotfix updates, it should be installed automatically as long as the NAS has Internet access.
What is the method to kill/stop the iscsi initiators from cli. Nothing I have found thus far has been successful.
