Chauser
Jul 14, 2021Aspirant
Netgear RR4360S FW 6.10.4 Apache2 Constantly fails. System more sluggish than usual.
Netgear RR4360S FW 6.10.4 Apache2 Constantly fails. System more sluggish than usual. Apache2 contniues to loop into safe-mode. Root Squash was stomping on shares, mistakenly tried to chmod the share,...
- Jul 28, 2021
Thanks,
I was able to fix my system by killing smb and nfs, and turning off the machines that had an iscsi connection. This allowed the apache to stablize in safe mode and for me to reload the firmware. The install was successful, but it still did not restart on its own; I still had to force it off about an hour of waiting.
mdgm
Jul 20, 2021Virtuoso
Chauser wrote:Understood, I use my system in an air-gaped envrionment.. I take it the hot-fix isn't an avaiable download...
You can get the one for x86_64 systems from /var/cache/apt/archives on a system that is connected to the internet or a Virtual Machine
Put that file on the NAS and install it using dpkg.
# dpkg -i readynasos_6.10.5+1_amd64.deb
I haven't looked to see if there's anything else in post-install scripts etc. but as far as the files included goes the hot-fix only has a replacement for the management service (readynasd).
Chauser wrote:How do I load firmware using rnutil firmware_update?
That requires an internet connection. That downloads the firmware from the update server
Chauser
Jul 28, 2021Aspirant
Thanks,
