SarahG
Mar 08, 2018Aspirant
No access to readycloud
The serial number is using the MAC address of eth0, how do I change this so that it displays the correct Serial Number so I can connect to ReadyCloud?
- Mar 10, 2018
This is now fixed.
mdgm-ntgr
Mar 08, 2018NETGEAR Employee Retired
On your RN102?
I wouldn’t have expected to see this problem on that having never seen it on that model.
This is an issue seen with a small batch of ReadyNAS Pro units.
SarahG
Mar 09, 2018Aspirant
when I upgraded the firmware the serial shoed as N0NE000200000 - after backing up I did a FACTORY reset and it changed the serial to the MAC address, how do I resolve this. A comment "I wouldn’t have expected to see this problem on that having never seen it on that model" isn't very helpful
- mdgm-ntgrMar 09, 2018NETGEAR Employee Retired
Please have a look at the PM I sent earlier today. You should find that more helpful.
I do think this should be straightforward for me to fix. Was just trying to confirm that you selected the correct model in your earlier post.
