TECH-JEFF
Jul 20, 2020Aspirant
power light blinking
Hi, For some reason I can't access our NAS. I try to detect the device and it's not seeing it. I did a manual IPscan on my network and I can see that it's getting an IP address. Power light is bl...
- Jul 23, 2020
TECH-JEFF wrote:
not quite sure about the warranty since our company bought this small company and this NAS was included in the buy out.
The mods ( JohnCM_S or Marc_V ) should be able to check. They'd need the serial number (and the domain name in the original company's email address would help). Send one of them a private message using the envelope icon in the upper right of the forum page.
Company acquisitions don't affect the warranty.
Jul 20, 2020Guru - Experienced User
TECH-JEFF wrote:
I guess this might be a disks issues, will try scanning both disks and see what comes up on the scan report.
Testing the disks is the next step.
Another possibility is that the sata bus in the chassis has failed. Do you have a spare disk that you know is working?
TECH-JEFF
Jul 22, 2020Aspirant
So I did test both drives and both are still in good condition as per SeaTools. I think something's wrong with the chassy.
I did try to press and hold the SYS button at the back, hold it whiel turning on the NAS. hold for 5 secs, no go, repeat the same process but hold it for 20 secs, no go
- StephenBJul 22, 2020Guru - Experienced User
Have you checked your warranty status? (3 years for the original purchaser).
- TECH-JEFFJul 22, 2020Aspirant
- StephenBJul 23, 2020Guru - Experienced User
