TECH-JEFF
Jul 20, 2020Aspirant
power light blinking
Hi, For some reason I can't access our NAS. I try to detect the device and it's not seeing it. I did a manual IPscan on my network and I can see that it's getting an IP address. Power light is bl...
- Jul 23, 2020
TECH-JEFF wrote:
not quite sure about the warranty since our company bought this small company and this NAS was included in the buy out.
The mods ( JohnCM_S or Marc_V ) should be able to check. They'd need the serial number (and the domain name in the original company's email address would help). Send one of them a private message using the envelope icon in the upper right of the forum page.
Company acquisitions don't affect the warranty.
TECH-JEFF
Jul 22, 2020Aspirant
So I did test both drives and both are still in good condition as per SeaTools. I think something's wrong with the chassy.
I did try to press and hold the SYS button at the back, hold it whiel turning on the NAS. hold for 5 secs, no go, repeat the same process but hold it for 20 secs, no go
Jul 22, 2020Guru - Experienced User
Have you checked your warranty status? (3 years for the original purchaser).
- TECH-JEFFJul 22, 2020Aspirant
- StephenBJul 23, 2020Guru - Experienced User
