ceitix
May 27, 2016Aspirant
problems to migrate ReadyCLOUD account
I have problems with an account is migrated in theory , but something has failed , when added to the nas , email me the user continues to appear and not as old accounts . only occurs with an account...
- Jun 15, 2016
Hello ceitix,
I was told that these accounts cannot be deleted. Since that account name has no registered Netgear product then I guess it should be okay to just not to use it then with ReadyCloud and use the new one you created.
Though, I am still waiting for other answers about it.
ceitix
Jun 04, 2016Aspirant
any news JennC ? thanks!
JennC
Jun 04, 2016NETGEAR Employee Retired
Hello ceitix,
I am still waiting for feedback too.
In the meantime, please try going to readycloud.netgear.com then click Sign in then click Upgrade to myNetgear account. Then click Upgrade your existing ReadyCloud account, enter the user's old ReadyCloud account (the old one before migrated to myNetegar) and its password. See if it will tell you that it is associated with the email address you use for myNetgear. If you get a bind the account with the email address, please do so.
Regrds,
- ceitixJun 04, 2016Aspirantok, thanks, I'm doing for days, which you indicate . But no changes , everything stays the same . I keep waiting and trying every day. thanks!
- JennCJun 04, 2016NETGEAR Employee Retired
Hello ceitix,
I see. I'll wait and see the feedback then. Sorry for the inconvenience.
- ceitixJun 12, 2016Aspirant
I think it will be preferable that you erase the account problems. I had to create another account with another email obviously.
:manfrustrated:
- JennCJun 14, 2016NETGEAR Employee Retired
Hello ceitix,
Does XXXXX@xxxx.xxx account have any registered unit to myNetgear support site?
- ceitixJun 14, 2016Aspirant
no.
ps: please not to publish private email accounts
- JennCJun 15, 2016NETGEAR Employee Retired
Hello ceitix,
- ceitixJun 26, 2016Aspirant
thanks for all JennC . I could solve the problem. I went to my admin page , then " cloud " , then to " cloud ready " and finally " leave" . I deleted all the information readycloud and I went back to link the accounts , and I could fix it.
Really, thank you very much for everything. :smileywink: :smileyhappy:
