onStephen
Oct 14, 2019Aspirant
R2304 v6.9.5 - Google Drive not syncing
Just got this last week and it's generally working well. I setup a one-way sync (local to cloud) to Google Drive on the cloud tab, and it shows connected with plenty of space available (I have a 1TB...
Icewaterhot
Oct 16, 2019NETGEAR Employee Retired
Hi onStephen,
Is the status of the Google disk showing red? Please try to leave and re-login.
- onStephenOct 17, 2019Aspirant
It's green, and has been green with every account I've tried. (So I have done "leave" several times already to switch accounts) It might show blue for a few seconds, when it says it's syncing, then it quickly goes green. Looks like it may just be an issue with the Home share. I created a new CIFS/SMB share and it seems to sync to GDrive as expected. The Home share though never syncs. There are no errors in the logs, sync related or otherwise. Is /data/home a special path excluded from cloud sync?
Thoughts? Thanks.
