onStephen
Oct 14, 2019Aspirant
R2304 v6.9.5 - Google Drive not syncing
Just got this last week and it's generally working well. I setup a one-way sync (local to cloud) to Google Drive on the cloud tab, and it shows connected with plenty of space available (I have a 1TB...
Icewaterhot
Oct 21, 2019NETGEAR Employee Retired
/data/home, It can also be synchronized. You can also create a folder synchronization.
- onStephenOct 23, 2019Aspirant
Right, but then that's exactly the thing.... the home folder won't sync or snapshot even though it "should". all other shares are working fine it would seem, just home seems confused for some reason and isn't working like it should. can i delete and recreate the entire home share and just start over without losing other data? Home seems clearly confused and to not be working as it should.
Thoughts? Thanks.
