PickMe4Beta
Apr 30, 2015NETGEAR Employee Retired
R7000 Firmware Version 1.0.4.28 supports ReadyCLOUD
Nighthawk has you covered even when you're away from home with NETGEAR genie® remote access and ReadyCLOUD® you can manage your network and have access to a secure personal cloud anytime, anywhere.
NETGEAR released new firmware for the Nighthawk R7000 router that allows you to plug in a USB drive to the router and use ReadyCLOUD to access files from anywhere, even from your smartphone. Download the new firmware onto your R7000 router today, attach a USB drive, and login to the router interface to get started with ReadyCLOUD.
How to get started with ReadyCLOUD and Nighthawk R7000 here.
What is ReadyCLOUD?
PickMe4Beta
NETGEAR Employee
What is ReadyCLOUD?
PickMe4Beta
NETGEAR Employee
- mondenathProdigyHave you tried with genie app. i believe the v .30 fixed the issue
- jayhawkmkInitiatereadyCLOUD registration from the router user interface does not work. It reports "registration failure" --- and yes, i have verified that my userid and pwd are correct, they work fine on the readyCLOUD website. How do i get the router interface to register readyCLOUD?
