augur
Sep 25, 2017Apprentice
Disable ReadyCloud sync on mobile access
Hi. I like to use the ReadyCLOUD client but like to disable folder sync if I am using WAN connection. Is that somehow possible? Cheers, Nils
BingkeX
Sep 25, 2017NETGEAR Expert
Hi augur,
Which Readycloud client do you use? Windows/MAC client or IOS/Android readycloud app?
For Windows/MAC client, there is no way to disable folder sync only with WAN connection. We have option to "pause sync" and "resume sync" for a sync job to disable folder sync regardless connection methods.
For IOS/Android readycloud app, there is an option "Use Cellular Data" to disable media backup when connection is 3G/4G, but no option to disable media backup only with WAN connection.
Hope this is helpful to you.
Best Regards.
