PetGriffin
Sep 24, 2015Aspirant
Inviting users via READYCloud
I have set up various user accounts on my ReadyNAS and want to allow them to access their home folders remotely using ReadyCLOUD. I logged onto ReadyCLOUD, clicked the home folder for user X and pre...
JennC
Sep 26, 2015NETGEAR Employee Retired
Hello PetGriffin,
The problem here is ReadyCloud user accounts are different from local users. Home shares are exclusive to the owner only. Local user will have his own home share, as well as ReadyCloud user. ReadyNAS treats ReadyCloud user as another user and not associated with any local user.
Here a sample scenario:
You shared Documents share to ReadyCloud user2, this ReadyCloud user2 is also the same person who is using local user2. This local local user2 has his own home share/folder local user2. When ReadyCloud user2 is able to see the ReadyNAS via ReadyCloud app or web browser, he will only be able to see the share he was invited to access, he will also see Home share but will not see what is inside it. If he uses ReadyCloud app and sync a folder from his local machine to the NAS, this folder from his computer will be copied as a new share to the NAS and this will only permit admin and ReadyCloud user2 to access. Home folder will contain the home share for ReadyCloud user too but other ReadyCloud users and local users will not be able will not see it the home share of ReadyCloud user2. Same with local user2, accessing the shares will give the local user2 his own home share but will not be able to see other local users' home share nor ReadyCloud users home share. Only local admin account and the main ReadyCloud account will be able to see all those home shares inside the Home share/folder.
Sorry if it's kind of confusing. I hope this helps. Please let me know if you have questions.
PetGriffin
Sep 26, 2015Aspirant
Hi Jenn
sorry, I'm really, really confused now .......
So in your example, user2 (who is the same person) has to have two user accounts on the ReadyNAS: one (let's call it user2A) for when he/she logs onto the ReadyNAS via the LAN to which it is attached (eg via Windows Explorer) and one (let's call it user2B) for when he/she logs onto the ReadyNAS remotely (eg via Internet Explorer). Now, user2B (cloud user) can't see the files associated with user2A (local user) even though they are the same physical person? As admin, I can give user2A access to the shared folder that user2B was invited from ... but there seems to be no way to set the access rights so that user2B can see what is in the home folder of user 2A. So, this means that user2B cannot log onto ReadyCLOUD to access files that are in his/her home folder (the home folder belonging to user 2A).
I hope I have mis-understood the situation and that someone will be able to put me right - but if this is how the system works then it has to be one of the dumbest things I have come across!! It basically means that the user has to keep two sets of files on the NAS: one for access via directly via the LAN and one for access indirectly via the web. Surely this can't be correct?!
Alun G
