DorsetTX
Jun 09, 2020Aspirant
Onedrive cloud backup, & Onenote issue
The seems to be an issue with and interaction between the Onedrive cloud backup and any Onenote files stored in a one drive folder being backed up to/from a NAS folder. By default Onenote creates...
Marc_V
Jun 17, 2020NETGEAR Employee Retired
Just to make sure, the OneNote files are getting deleted from OneDrive and your Local storage? or on the OneDrive and NAS?
DorsetTX
Jun 17, 2020Aspirant
Hi Marc,
The contents of OneDrive and the NAS are in sync with each other. The .one file disappears on both and the folder of the same name appears on both once the cloud sync completes.
I suspect the issue is one of timing delays between OneDrive and the NAS when an application rapidly creates, renames, deletes and recreates a file or files starting and finishing with a file of the same name.
There is long standing issue with a similar problem with larger Adobe PSD files when saved to the NAS. At the start of save the application creates a temp file, once the save is complete the file is renamed to the save name. Due to the time delays and the way the sync works. It appears the initial (empty) tmp file gets bounced backwards and forwards, causing only the temp file to survive. With this application I have to remember to save the PSD to local hard disk then copy the completed file to the NAS.
R.
