Nepamoon
Feb 15, 2016Aspirant
ReadyCloud Desktop App not working but web portal is working
I haven't been able to access my NAS via the desktop app however I can access the web portal and see my files with no issue. I've used various version of the desktop app and still have the same issue...
BrianL2
Feb 29, 2016NETGEAR Employee Retired
Hi scravatt,
Will it be possible if you can break the bond or teaming between your adapters and give it another try?
Kind regards,
BrianL
NETGEAR Community Team
scravatt
Feb 29, 2016Apprentice
I would think netgear should look into it and offer a firmware or other fix if that's the case. Also, I have not changed the configuration on my devices since I set them up 1 year ago. So, somethjing netgear did recently causes these issues...I went back 3 versions of FW and same issue happens. It's something on netgear's backend of their readycloud apps that makes remote access very flaky. Btw, I have 2 NAS boxes at 2 different places and the same flaky issue happens when I access via readycloud app. If disabling iPv6 fixes it, then netgear should look into fixingthe IPv6 issue, correct?
- NepamoonFeb 29, 2016Aspirant
Even with IPv6 and AV disable ... still doesn't work for me ... kinda giving up and just use web portal
- BrianL2Feb 29, 2016NETGEAR Employee Retired
Hi scravatt,
Don't worry we will look closely into this problem and see if we could duplicate it. For the meantime, try what we suggested and let us know what happens.
Kind regards,
BrianL
NETGEAR Community Team - scravattMar 05, 2016Apprentice
same here.. I thought it was working...but yesterday and today it won't connect via readyapp only web portal...ugh
- scravattMar 12, 2016Apprentice
I was able to disable ipv6 by breaking the network bond, disabling ipv6 on each adapter and then creating the bond again (it now shows disabled)....so far for a week now, both of my NAS system are accessible via the readycloud windows and iphone app. I'll try it for one more week and see if it's stable....hopefully this will fix the problem.
- BrianL2Mar 13, 2016NETGEAR Employee Retired
Hi scravatt,
I was able to connect just fine using the ReadyCLOUD desktop app, mobile app and the web portal (files and folder loads faster than a week ago). Let me know if your connection becomes stable after a week.
Kind regards,
BrianL
NETGEAR Community Team - scravattMar 24, 2016Apprentice
so far so good...stable after several weeks.
