Guvner27's avatar
Guvner27
Re: ReadyCloud Desktop Client - Network Error ReadyCloud Server is unavailable
This update has worked well for all my remote users that had this 'not connecting' issue - thanks for that.   However, I have an issue on the PC I user as admin, where the install does not comple...
  • Guvner27's avatar
    Guvner27
    Mar 25, 2019
    I found a fix tonight and now its working.  Repro steps:
    - Try installation - it stalls during installation (per above thread)
    - Open Windows Task Manager
    - Find READYCLOUD.  It has 3 sub-tasks showing
    - Select 'READYCloud Utils' and end only that sub-task (not the master task)
    - Installation then resumes and the app completes installation
ProSupport for Business
