Guvner27
Mar 05, 2019Aspirant
Re: ReadyCloud Desktop Client - Network Error ReadyCloud Server is unavailable
This update has worked well for all my remote users that had this 'not connecting' issue - thanks for that.
However, I have an issue on the PC I user as admin, where the install does not comple...
- Mar 25, 2019
I found a fix tonight and now its working. Repro steps:
- Try installation - it stalls during installation (per above thread)
- Open Windows Task Manager
- Find READYCLOUD. It has 3 sub-tasks showing
- Select 'READYCloud Utils' and end only that sub-task (not the master task)
- Installation then resumes and the app completes installation
Icewaterhot
Mar 07, 2019NETGEAR Employee Retired
Hi nextwavepc Guvner27 ,
I saw 2 issues on the screenshot.
1. The code appears on the readycloud app.
2. ReadyCLOUD can not be installed, will be stuck in the registry.
Is there any security software on your PC that will prevent Readycloud installation?
If the code appears on the readycloud app, please install this patch package and try it out.
- Guvner27Mar 08, 2019Aspirant
Hi Icewaterhot
Thanks for the suggestion. There shouldnt be anything blocking the app as it worked just fine before this update. I ran the patch but it gives an error saying "not applicable to my system" (I ran both options just to be sure, same each time). Screenshot attached.
Any further suggestions much appreciated, esp as it sounds like a registry issue from you note.
- IcewaterhotMar 10, 2019NETGEAR Employee Retired
Hi Guvner27 ,
Your situation should be the second situation I said, you need to check the registry, the normal situation should be my screenshot below.
"configure registry settings" . We also need to check the version of the windows. What is your version number?
- Guvner27Mar 13, 2019Aspirant
I see the correct install on other PCs, just not this one, my admin PC (which had been running the app just fine before this update).
As you saw from my earlier screenshot, it's not getting to "configure registry settings". When you say "check the registry", what am I checking for?
Windows 10 Home v1803 build 17134.590
BTW - I did not see any code (presume you mean on the desktop app?). This installation is failing during the install of the desktop app update, so I dont have an app anymore.
