Guvner27
Mar 05, 2019Aspirant
Re: ReadyCloud Desktop Client - Network Error ReadyCloud Server is unavailable
This update has worked well for all my remote users that had this 'not connecting' issue - thanks for that.
However, I have an issue on the PC I user as admin, where the install does not comple...
- Mar 25, 2019
I found a fix tonight and now its working. Repro steps:
- Try installation - it stalls during installation (per above thread)
- Open Windows Task Manager
- Find READYCLOUD. It has 3 sub-tasks showing
- Select 'READYCloud Utils' and end only that sub-task (not the master task)
- Installation then resumes and the app completes installation
Icewaterhot
Mar 07, 2019NETGEAR Employee Retired
Hi nextwavepc Guvner27 ,
I saw 2 issues on the screenshot.
1. The code appears on the readycloud app.
2. ReadyCLOUD can not be installed, will be stuck in the registry.
Is there any security software on your PC that will prevent Readycloud installation?
If the code appears on the readycloud app, please install this patch package and try it out.
Guvner27
Mar 08, 2019Aspirant
Hi Icewaterhot
Thanks for the suggestion. There shouldnt be anything blocking the app as it worked just fine before this update. I ran the patch but it gives an error saying "not applicable to my system" (I ran both options just to be sure, same each time). Screenshot attached.
Any further suggestions much appreciated, esp as it sounds like a registry issue from you note.
