Viffergb
Mar 05, 2019Luminary
ReadyCloud Desktop Client
Switched on my Windows 10 laptop this morning and was confronted with the following when my 'Desktop Client' attempted to sign me in:-
"Network Error
ReadyCLOUD server is unavailable"
- Retired_MemberMar 05, 2019
Hello
ReadyCLOUD dev raised ReadyCLOUD security level on server so it blocked access from old ReadyCLOUD client,you need to upgrade latest ReadyCLOUD client from ReadyCLOUD web portal or download it from below link
http://readycloud.netgear.com/client/install/ReadyCloudSetup.exe
Marc_V
Mar 05, 2019NETGEAR Employee Retired
Hi Viffergb
Updating the Client App should resolve the issue, use the link Retired_Member provided.
Regards
Viffergb
Hi Marc_V and Deniro
Pleased to report that downloading and installing the latest version as advised by Deniro has fixed my problem.
Many thanks to both of you for your help, it is much appreciated 👏.
Just a thought, but would it be a good idea to post a 'sticky' under 'Desktop Client Connect to Server Problem' for others to view and take appropriate action as described.....or is it posted somewhere and I've just not seen it!
Anyway, thanks again,
Graham
