Brenakie772
Mar 21, 2017Tutor
ReadyCLOUD isn't Syncing
Hi, Read some related threads and couldn't find a solution. I have a PC directory on the readycloud and it's synced. I was off site and needed to do some work. I accessed the file (.PSD)...
- Mar 24, 2017
Do you see a green tick on share icon and "synchronized" status after sync is finished? Like
Where do you check your local PC folders?
YES!
Notice: When you stop a one-way sync job, the original local folder on your PC don't have any connect with nas. After you create a 2-way sync job with the folder on nas again, then windows client app would create a new local folder on PC. You can click the share icon with a 2-way sync job to access its local synced folder.
I didn't realize that it created a whole new directory (that was my issue, I kept looking where it always is/was), so this will be the new local directory (c:/users/username/comp_name (readyNAS)/dir/dir...) that I need to use/access. I should be all set, moving forward. I want to thank you for your time, help and and most of all your patience! I apprecaite it!
BingkeX
Mar 22, 2017NETGEAR Expert
Hello Brenakie772,
Yes, i am still in client app when i say create "sync with PC" or "Backup PC Folders" job.
First of all, you have confirmed that your original issue is you just created a one-way "backup pc folder" job, right?
Secondly, when i mentioned to create 2-way sync job by clicking "Sync with PC" and create one-way sync job by clicking "Backup PC Folder", i just mean that do these operations for a folder which don't have a sync job currently.
In your case now, the folder have a sync job with it, so you just see "pause/stop backup" menu.
If you still want to change your original folder to a 2-way sync job, you can click "stop backup", then select the original folder and click "sync with PC" to create a 2-way sync job.
Best Regards.
Brenakie772
Mar 23, 2017Tutor
Bingke,
I am NOT able to toggle between the modes when I click the folder icon but....
I re-read your last post and the last thing you mentioned worked!!!
Just waiting for the folders to sync, I'll keep you posted!
B
- Brenakie772Mar 23, 2017Tutor
Files are not sync'ing back down to my PC. Opened a call w/ support, I'll keep you posted.
- BingkeXMar 23, 2017NETGEAR Expert
Hi Brenakie772,
So in your case now, you can try to click the share icon with a 2-way sync job to access your share to see if files are downloaded.
Don't check your original local pc folder location, it don't have any connect with nas after you stop one-way sync job.
Best regards.
- Brenakie772Mar 24, 2017Tutor
YES!
