jbuchal's avatar
jbuchal
Tutor
May 27, 2020
ReadyCloud "no volume or usb disk" error message
I have been using ReadyCloud for a long time without problems.  Now I cannot acces the NAS remotely, though it still works fine on the local network.  I can sign in just fine, but can't see anything,...
  • JohnCM_S's avatar
    JohnCM_S
    May 28, 2020
    Hi all,
    There was an issue in viewing the shared folders on the ReadyCLOUD web portal but this should be fixed now. Please check if you are now able to see the shared folders on the web portal.
