Lucha
Apr 26, 2017Aspirant
Readycloud
I backup media on my iphone to my ready nas 102 It used to go fast now it takes forever!!!! What could be the problem??
BingkeX
Apr 26, 2017NETGEAR Expert
Hello Lucha,
What is the file type you are backuping? If the uploading file is a video file, maybe the uploading progress update slowly, as the video file size is much larger than a photo file.
And what is the connection type of your device? You can see connect status by sliding down the device access page and check it on the top . The connection type maybe "Connected(LAN)" or "Connected(VPN)" or "Connected(ReadyCLOUD)". The LAN connection is the fatested one, and the "ReadyCLOUD" connection is the slowest one. It is possible that it is LAN connection you used to connect.
Best Regards.
