SAS1201
Jun 12, 2019Aspirant
Readynas Apache2 issues
I am having issues recently since I upgraded to 6.10.1. First of the images on the Admin web portal are not loading for the APPS that I have running. The next issue, is I have a few apps that are n...
WhoCares_
Jun 13, 2019Mentor
Sounds like you're behind a proxy. What you can try is to tell apt to use that proxy by
- creating the file /etc/apt/apt.conf.d/00_proxy (using "vi /etc/apt/apt.conf.d/00_proxy")
- add the following lines:
Acquire::http::proxy "http://<proxy>"; Acquire::https::proxy "https://<proxy>"; Acquire::ftp::proxy "ftp://<proxy>"; Acquire::socks::proxy "socks:<proxy>";
(replace <proxy> with the actual location of the proxy you're using.
- save the file
- try the "apt update && apt full-upgrade" again
-Stefan
WhoCares_
Jun 13, 2019Mentor
Smiley replacements in code blocks. Really, now?
-Stefan
