GPSIS_HQ
Aug 06, 2017Guide
READCLOUD NOT SYNCING FOLDERS
My ReadyNAS desktop client is not syncing the changes i make to the original folder. The desktop client indicates the folder is sync'd but the files in the NAS does not coorespond with the files ...
- Retired_MemberAug 07, 2017
Backup PC folder:
copy data to you local folder,the new data will sync to NAS share
delete data in your local folder,the data will not be deleted in NAS share.
delete data in your NAS share,the data will not be deleted in local folder.
Sync with PC
Desktop client will create a local folder in c drive of Windows.all the data change in both sides will be synced,you should use Sync with PC to instead of Backup PC folder.
Retired_Member
Aug 06, 2017Hello GPSIS_HQ
Is your share created by “Backup PC folder"?ReadyCLOUD client only sync data bidirectionally if your share was created by "Sync with PC" .
