GPSIS_HQ's avatar
Aug 06, 2017
READCLOUD NOT SYNCING FOLDERS
My ReadyNAS desktop client is not syncing the changes i make to the original folder.   The desktop client indicates the folder is sync'd but the files in the NAS does not coorespond with the files ...
  • Retired_Member's avatar
    Retired_Member
    Aug 07, 2017
    Backup PC folder:
    copy data to you local folder,the new data will sync to NAS share
    delete data in your local folder,the data will not be deleted in NAS share.
    delete data in your NAS share,the data will not be deleted in local folder.
    Sync with PC
    Desktop client will create a local folder in c drive of Windows.all the data change in both sides will be synced,you should use Sync with PC to instead of Backup PC folder.
ProSupport for Business
