nrkent
Jan 10, 2015Aspirant
ReadNAS 104 won't boot - says "Boot from USB"
I have been running a ReadyNAS 104 with two disks for just over a year. A week ago I got messages saying that one of the disks was about to fail. I tried to log on to the Readnas locally and via R...
mdgm-ntgr
Jan 11, 2015NETGEAR Employee Retired
If you get an RMA, you can put a spare disk (must not be from your array) in the 104, use that to update the firmware on the NAS, verify the firmware update is successful, then power down, remove your spare disk and migrate your disks across (keep order the same) from the dead unit.
If you contact support they could confirm if an RMA is required and if so let you know what needs to happen.
