appierro
Jan 14, 2018Apprentice
Readnas cannot connect to readycloud
ReadNas cannot connect to Readycloud. Something is preventing. Disks are good. Local Admin account is set up with same email as MyNetgear account.
- Jan 25, 2018
Netgear engineers connected to my NAS via ReadNAS Diagnostic mode and removed a corrupt Config file. Once they removed the config file, I was able to connect to ReadyCLOUD. Thanks,
appierro
Jan 22, 2018Apprentice
Sent you the port
appierro
Jan 25, 2018Apprentice
- vverma01Jan 29, 2018Tutor
I am facing exact same issue - message says "Something is preventing the ReadyNAs from.....".
I am unable to access it from outside my home network. I appreciate if Netgear can hep me with the diagnostic and fix.
Kind regards,
Vinay Verma
- rickr1Feb 09, 2018Aspirant
Hi Appiero,
I am having this problem as well and by any chance do you know the location of this config file that the engineers renamed/removed?
I have 3 ReadyNAS servers running and only one of them is not connecting to ReadyCloud; I am receiving messages that ReadyNAS Replicate will be decommissioning and I do not want to be left with this NAS (my primary) not being setup properly.
Cheers,
Rick
ReadyNAS Replicate setup that i need to replicate with ReadyCloud
- RealoneFeb 12, 2018Tutor
That would be great. This can be a simple fix if we just know the procedure.
- Marc_VFeb 12, 2018NETGEAR Employee Retired
Hi rickr1
I would advise contacting NETGEAR Support and create a case, they can assist you with your ReadyNAS units.
Regards
- vverma01Feb 12, 2018Tutor
Creating a case with ReadyNAS - will it be a chargable activity? Mine is out of warranty.
Kind regards,
Vinay Verma
- StephenBFeb 12, 2018Guru - Experienced User
wrote:
If your NAS was purchased between June 1, 2014 and May 31, 2016 then lifetime Chat Support is available.
This doesn't apply to the RN100 or RN200 platforms, it is limited to the "business" OS 6 ReadyNas (Rackmount, RN300 series and above).
Unfortunately, mine is 2013. Can ReadyNAS mention steps to fix here which we can apply ourselves?
It doesn't seem genuine that a patch from Netgear created this issue and we are forced to pay for support to get it fixed.
Ideally it should be treated as defect and Netgear should issue a patch to fix it automatically.
Kind regards,
Vinay Verma
Hi StephenB,
Yes, my ReadyNAS is conected to internet - I am seeing green internet check box.
I am also recieveing upgrade notifications. Recently I upgraded to 6.9.2.
Kind regards,
Vinay Verma
wrote:
hopefully StephenB can reach out to you as well. I believe he's working with vverma01 to get his resolved.
As far as ReadyCloud goes, I focus on whether the NAS has the right network connection to reach the internet. I can't really go further than that - I access my own NAS remotely using VPN, not ReadyCloud. So once it's clear that the issue isn't the network itself, I need to leave it to the Netgear team.
- rickr1Feb 13, 2018Aspirant
Hi Marc_V,
I purchased the one i am having issues with 2nd hand and I do not have access to the original purchase receipt, so I would need to pay for the service call. But honestly this is just so wrong, you should provide OS upgrades for the purposes if fixing bugs and not to generate paid service requests. I just hope that it is not too expensive.
I am quite disapponted with that fact, but I need to be able to access these devices when I am away from home.
RIck
Thanks Stephen. My NASes all have full network access to the Internet and are all configured in exectly the same way with the exception of this problem of it not being able to register with readycloud.
Actually, I may turn this around and provided I can swap my drives around between the NASes maybe I acn demote this one to a backup role and promote one of my other ones to be the primary role. But realistiacally I should not be having this problem at all. The ALL my NASes are running at the same OS releases and I upgrade all of them at the same time.
Netgear should publish more information on this issue if they cannot automate a patch.
Cheers,
Rick
- mdgm-ntgrFeb 13, 2018NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- StephenBFeb 14, 2018Guru - Experienced User
Netgear's policy is that they won't provide paid support for used ReadyNAS (even if you are willing to pay). So you are dependent on this forum.
You could try swapping disks with one of your new NAS, and if the problem moves with the disks you would be able to use paid support.
- appierroFeb 14, 2018Apprentice
rickr1 you may not have to pay or play around with swapping disks. I was out of support as well and a Netgear Engineer picked the issue up from this community, remoted in to my NAS and deleted the corrupt file. It was very simple, took less than 5 minutes and was very impressive. This is an issue that affects many users and it seems the resolution requires deleting this corrupt file.
Can a Netgear Engineer reach out to Rick?
mdgm-ntgr already has.
My take was that Rick wasn't intending to use paid support for this; my info on paid support policies was really for future reference.
FWIW, personally I don't use ReadyCloud at all (I prefer OpenVPN and ZeroTier for remote access). If I did use it, I'd only enable it for one NAS.
- vverma01Feb 14, 2018Tutor
Can Netgear support atleast publish the details the file to be deleted. It will help users to make full use of ReadyNAS.
Else Iin absence of support, I am thinking of one time investment to migrate to Netgear competitor.
Kind regards,
Vinay Verma
- mdgm-ntgrFeb 15, 2018NETGEAR Employee Retired
Can you provide me logs from your system that can't connect to ReadyCLOUD. Thanks.
- vverma01Feb 15, 2018Tutor
Hi StephenB and mdgm,
I just mailed logs for mdgm's attention.
Kind regards,
Vinay Verma
If it is a problem with the config file as it appears to be in vverma01's case there are a few options:
The first is:
1. Backup your data
2. Verify your backup is good
3. Do a factory default (wipes all data, settings, everything)
4. Restore your data from backup and manually reconfigure the NAS
Or I can discuss an alternative option via PM.
- rickr1Feb 15, 2018Aspirant
HI Guys,
Actually I was/am prepared to pay for a one off support charge and I called the call centre and spent considerable time on the phone with the operator. But diring the call I discovered another problem with my ReadyNAS which is that it is reporting back a different serial number from the one on th sticker underneath it. The sticker is the correct format (13 chars) but the reporting back from the admin page is only 11 chars. This would be contributing to the problem connecting to ReadyCloud should my device have been supported. This leaves me to the next question and that is that there is a difference between firmware and OS even though the OS updates are called firmware updates. I was informed that my model is not supported that is becasue the firmware is not supported (even though I am running the current OS release 6.9.1)
Ayway apparently my nas os not supported wvwn though I am running the current OS (not firmware?????)
As to connecting via a vpn, that looks like the only option available to me and I just purchased another 6 new Seagate IronWolf 4TB as I am now going to restructure all of my primary storagea nd backup configuration. So if anyone could direct me to a recommended process for setting up a VPN and establishing a reliable remote connection to it I would greatly appreciate it.
Thanks everyone for all of your help so far.
Cheers,
Rick
