LeapingLemming's avatar
Jun 10, 2017
ReadyCLOUD not connecting
I have read thread after thread for the past two days trying to work why I cannot connect to Readycloud anymore. Nothing suggested works.
Some info:
1  ReadyNAS 104 with 4 drives on 6.7.4
2  Readycloud for windows is v1.5
3  Not sure when my issue started but the last file was synced to my NAS on 30 May 17 (working fine for a year before that.
Symptoms
1  In readycloud.netgear.com
  a  I can see the device and discover it.
  b  … but I cannot “manage” it, I don’t see any shares.
2  In the ReadyNAS admin page
  a In admin > cloud, both Internet Available and Services Available are green ticks
  b … but when I try to turn ReadyCloud on, it errors with “something has prevented the readynas from connecting to the readycloud server".
3  The windows readycloud app continually claims the NAS is offline
4  RAIDar sees the NAS and eports all is healthy and allows me to browse the files.
5 I have factory-reset the OS, tried the beta of 6.7.5, reinstalled the app, and changed setting based on other threads in the forum.
I have downloaded logs using RAIDar but I’m not sure what log to look at.  Any ideas would be gratefully received,
Thanks
  • Finally fixed.  I think it was related to a deleted user message months ago.  Regardless it took Netgear L3 support to fix, something about removing old settings.   Thanks for your help anyway
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello LeapingLemming,
    Can you please check on the admin page's Accounts> Cloud Users if your ReadyCloud account is listed under Name and Email?
    • JennC's avatar
      JennC
      If you have your ReadyCloud login set as "signed in as" under Cloud > ReadyCloud then that login should be listed under Accounts > Cloud users. Can you check please what you have under Cloud > ReadyCloud?
      • Readycloud is "off" for some reason and I can't turn it on.
        I try to "join" using my email address and  it errors with "Something is preventing ReadyNAS from connecting to the ReadyCloud server.  Please reboot your NAS and try again".  I have rebooted many times.
        Green ticks against Internet Available and Services Available
        The settings button does not show.
ProSupport for Business
