LeapingLemming
Jun 10, 2017Tutor
ReadyCLOUD not connecting
I have read thread after thread for the past two days trying to work why I cannot connect to Readycloud anymore. Nothing suggested works. Some info: 1 ReadyNAS 104 with 4 drives on 6.7.4 2 Re...
- Jun 23, 2017
Finally fixed. I think it was related to a deleted user message months ago. Regardless it took Netgear L3 support to fix, something about removing old settings. Thanks for your help anyway
JennC
Jun 12, 2017NETGEAR Employee Retired
Hello LeapingLemming,
Can you please check on the admin page's Accounts> Cloud Users if your ReadyCloud account is listed under Name and Email?
JennC
Jun 13, 2017NETGEAR Employee Retired
If you have your ReadyCloud login set as "signed in as" under Cloud > ReadyCloud then that login should be listed under Accounts > Cloud users. Can you check please what you have under Cloud > ReadyCloud?
- LeapingLemmingJun 13, 2017Tutor
Readycloud is "off" for some reason and I can't turn it on.
I try to "join" using my email address and it errors with "Something is preventing ReadyNAS from connecting to the ReadyCloud server. Please reboot your NAS and try again". I have rebooted many times.
Green ticks against Internet Available and Services Available
The settings button does not show.
I do have a deleted user message on 30-March-17. Could this have caused downstream issues?
- StephenBJun 14, 2017Guru - Experienced User
Have you seen this?
https://community.netgear.com/t5/ReadyCLOUD/Having-ReadyCLOUD-problems-since-3-30-17/td-p/1259697
- JennCJun 14, 2017NETGEAR Employee Retired
Did you have ReadyCloud users before on the NAS that they already have home shares? If so, backup the files stored to their home shares.
Then check under System > Settings if UPnP is enabled. It should.
- LeapingLemmingJun 14, 2017Tutor
VPnP is enabled
All the shares I set up ar at the "base" directory (the same level as "home"). There is no data in the "home" directory nor in any folder that was created for the users. I assume this is OK?
To make sure this is how the directory tree looks:
NAS
- Folder 1
- Folder 2
- Home
- User 1
- User 2
- Folder 3
All data is in the folders 1,2,3 and no data in the user 1 or 2.
Ao all good?
- WilliamJJun 14, 2017Aspirant
I have a exact same issue which I have been annoyed for quite a while.
- JennCJun 15, 2017NETGEAR Employee Retired
Can you please post the error message when enabling ReadyCloud and upload system logs to wikisend.com then PM me the download link.
- WilliamJJun 15, 2017Aspirant
This has happend to me since the firmware was upgraded to 6.7.4
