mc41
Jan 22, 2017Aspirant
ReadyCLOUD not connecting
Trying to connect via readycloud. Says nas is off line which it isnt
any solution ?
Cheers
bill
mc41 wrote:
Go into admin page and add it ?Yes. It's under network settings (ipv4).
What firmware are you running on the ReadyNAS?
- mc41AspirantNot sure as im out. But was upgraded last week.
- JennCNETGEAR Employee Retired
Hello mc41,
Are you logging in via ReadyCloud portal? Please let us know the current firmware version.
Also, please see if you are using the same account that is shown as "signed in as" on the admin page's Cloud > ReadyCloud.
Hello mc41,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- mc41AspirantNo change. Says logged in. NAS off line which it isn't
Hello mc41,
Please provide more info.
- What is the model number of the NAS?
- What is the current firmware version?
- Are you logging in using the main ReadyCloud account?
- Is the ReadyNAS getting on the Internet?
- Are you using a computer that is connected to the same network where the NAS is when logging in to ReadyCloud portal?
- When you use ReadyCloud app on Windows/Mac desktop or on an Android, do you get the same problem?
- Do you log in using ReadyCloud account that is in an email address format?
- mc41Aspirant
Readynas 104
serial 3EPE4CEH00DF2
firmware 6.6.1
log in on mac desktop using RAIDar no problem,the readycloud sitting ontop screen in tool bar section, just spinning saying connecting (which it never stops tying to do and never connects
Are you logging in using the main ReadyCloud account? ??? Not sure what you mean
Is the ReadyNAS getting on the Internet? ???? not sure what yiou meanAre you using a computer that is connected to the same network where the NAS is when logging in to ReadyCloud portal? (cant log onto portal)
When you use ReadyCloud app on Windows/Mac desktop or on an Android, do you get the same problem? yes
Do you log in using ReadyCloud account that is in an email address format? the user name on the computor toolbar is not a email setup
- mc41AspirantOk. Internet available light is not on, place cursor over ? Mark and says. " communication error check your internet connection or DNS settings."
- mc41AspirantDHCP.
You might try adding 8.8.8.8 as a ReadyNAS DNS server. That's google's open DNS server.
- mc41AspirantGo into admin page and add it ?
- phsandmeierAspirant
I have the same problem... with DNS 8.8.8.8
can you help me?
- mc41AspirantIm still having problems logging in remotely
Go to readycloud app
Update device
Finds NAS
Logged in
Connecting
Nothing 😡 - mc41AspirantAlso says it is online.
- mc41AspirantHave done this. Its only on the nas sdmin that this needs to be done ?
- mc41AspirantSo my next step in the elimination trial would b ? 🙄
mc41 wrote:
So my next step in the elimination trial would b ? 🙄Given the number of posts from people who aren't connecting, I'd suggest letting it rest it bit. Its possible (maybe even likely) that this is an issue in the Netgear cloud, not with your devices.
FWIW, I tried Remote some years ago, and wasn't happy with it's performance or reliability back then. So I switched to other solutions (and am currently using OpenVPN with ddns). A backup alternative to ReadyCloud might be something you need anyway.
