mc41
Jan 21, 2017Aspirant
ReadyCLOUD not connecting
Trying to connect via readycloud. Says nas is off line which it isnt any solution ? Cheers bill
mc41
Jan 28, 2017Aspirant
Go into admin page and add it ?
- StephenBJan 28, 2017Guru - Experienced User
mc41 wrote:
Go into admin page and add it ?Yes. It's under network settings (ipv4).
- phsandmeierJan 30, 2017Aspirant
I have the same problem... with DNS 8.8.8.8
can you help me?
- StephenBJan 30, 2017Guru - Experienced User
can you help me?
Does the cloud page show a good internet connection?
If not, are you using a static IP address?
