mc41
Jan 21, 2017Aspirant
ReadyCLOUD not connecting
Trying to connect via readycloud. Says nas is off line which it isnt any solution ? Cheers bill
mc41
Jan 31, 2017Aspirant
So my next step in the elimination trial would b ? 🙄
- StephenBJan 31, 2017Guru - Experienced User
mc41 wrote:
So my next step in the elimination trial would b ? 🙄Given the number of posts from people who aren't connecting, I'd suggest letting it rest it bit. Its possible (maybe even likely) that this is an issue in the Netgear cloud, not with your devices.
FWIW, I tried Remote some years ago, and wasn't happy with it's performance or reliability back then. So I switched to other solutions (and am currently using OpenVPN with ddns). A backup alternative to ReadyCloud might be something you need anyway.
