mc41
Jan 21, 2017Aspirant
ReadyCLOUD not connecting
Trying to connect via readycloud. Says nas is off line which it isnt any solution ? Cheers bill
mc41
Jan 26, 2017Aspirant
No change. Says logged in. NAS off line which it isn't
- JennCJan 27, 2017NETGEAR Employee Retired
Hello mc41,
Please provide more info.
- What is the model number of the NAS?
- What is the current firmware version?
- Are you logging in using the main ReadyCloud account?
- Is the ReadyNAS getting on the Internet?
- Are you using a computer that is connected to the same network where the NAS is when logging in to ReadyCloud portal?
- When you use ReadyCloud app on Windows/Mac desktop or on an Android, do you get the same problem?
- Do you log in using ReadyCloud account that is in an email address format?
- mc41Jan 28, 2017Aspirant
Readynas 104
serial 3EPE4CEH00DF2
firmware 6.6.1
log in on mac desktop using RAIDar no problem,the readycloud sitting ontop screen in tool bar section, just spinning saying connecting (which it never stops tying to do and never connects
Are you logging in using the main ReadyCloud account? ??? Not sure what you mean
Is the ReadyNAS getting on the Internet? ???? not sure what yiou meanAre you using a computer that is connected to the same network where the NAS is when logging in to ReadyCloud portal? (cant log onto portal)
When you use ReadyCloud app on Windows/Mac desktop or on an Android, do you get the same problem? yes
Do you log in using ReadyCloud account that is in an email address format? the user name on the computor toolbar is not a email setup
- StephenBJan 28, 2017Guru - Experienced User
mc41 wrote:
Is the ReadyNAS getting on the Internet? ???? not sure what yiou meanLook in the admin web ui and see if you see "internet available" with a green checkbox in front of it on the cloud page.
Did you set up a readycloud account on the portal? ReadyCloud accounts are managed by Netgear, and they all are in email-address format.
