jankes
Jul 02, 2017Aspirant
Readycloud App problems STILL not resolved
Hello, I have this problem since past few months, and I have been watching some similar topics with this case. Unfortunately any of this haven't been resolved: https://community.netgear.com/t5...
jankes
Jul 03, 2017Aspirant
Hello Marty_M,
Thank you for your reply.
I can connect. I think problem is with language files or etc..?
Please see: https://ibb.co/fOXJCv
Marty_M
Jul 04, 2017NETGEAR Employee Retired
Hello jankes,
It is nice to hear all is working now and just minor setting that need to be check. Since the issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team
- jankesJul 04, 2017Aspirant
Hello Marty.
No it is NOT WORKING.
There ae still MAJOR ISSUES.
Folder name creation is wrong on the server. We cant change it. It creates name "SHARE_BACKUP_NAME" always, and it can't be changed.
Thanks,
Jan
- Marty_MJul 05, 2017NETGEAR Employee Retired
Hello jankes,
How are you trying to create or rename the folder are you doing locally or via readycloud?
Marty_M
NETGEAR Community Team- jankesJul 05, 2017Aspirant
I'm doing this by ReadyCloud App in tray
Also, non of options are able to change. for example language etc.
