keroppi
Dec 15, 2014Tutor
ReadyCLOUD Client : How to configure files to be ignored
Hello, I'm using ReadyNAS 104 and I have a question about the new ReadyCLOUD Client (Windows ver.). I'm using the sync feature of the ReadyCLOUD Client to sync files that I used to sync with Ready...
keroppi
Dec 16, 2014Tutor
jaffacake wrote: This would be handly.
Also, being able to disabled the ignored notification would be good.
So the files to ignore can't be configured as of this moment?
If so I'd like to request this feature for the upcoming versions.
It would be nice if the user can specify the files to sync using regular expression or something.
Within the files that start with a dot, there are both files I want and don't want to sync.
