Nepamoon
Feb 15, 2016Aspirant
ReadyCloud Desktop App not working but web portal is working
I haven't been able to access my NAS via the desktop app however I can access the web portal and see my files with no issue. I've used various version of the desktop app and still have the same issue...
Nepamoon
Thanks for the welcome :)
Firmware: 6.4.2
Apps - AV only
I am currently away and isn't able tolog into the admin page to see what services i have.
BrianL2
Feb 15, 2016NETGEAR Employee Retired
Hi Nepamoon,
Does this happen too on another PC (WIN7 or other)? How about using the mobile app?
Kind regards,
BrianL
NETGEAR Community Team
- mdgm-ntgrFeb 15, 2016NETGEAR Employee Retired
Can you try disabling the Anti-Virus service under System > Settings > Services and see if this helps?
- matsyouriFeb 16, 2016Aspirant
Same here. Yesterday it accidentally worked for some time. Antivirus service disabled. Tried on win10 and android. Local connection is ok, remote one stucks on "connecting..." in win10 and "refreshing..." in android. Hope this helps.
- BrianL2Feb 16, 2016NETGEAR Employee Retired
Hi matsyouri,
Can you confirm both internet and services are both online under the Cloud tab? Are the files visible in the ReadyCLOUD web portal (https://readycloud.netgear.com/)?
Kind regards,
BrianL
