Nepamoon
Feb 15, 2016Aspirant
ReadyCloud Desktop App not working but web portal is working
I haven't been able to access my NAS via the desktop app however I can access the web portal and see my files with no issue. I've used various version of the desktop app and still have the same issue...
BrianL2
Feb 29, 2016NETGEAR Employee Retired
Hi scravatt,
Will it be possible if you can break the bond or teaming between your adapters and give it another try?
Kind regards,
BrianL
NETGEAR Community Team
scravatt
Feb 29, 2016Apprentice
I would think netgear should look into it and offer a firmware or other fix if that's the case. Also, I have not changed the configuration on my devices since I set them up 1 year ago. So, somethjing netgear did recently causes these issues...I went back 3 versions of FW and same issue happens. It's something on netgear's backend of their readycloud apps that makes remote access very flaky. Btw, I have 2 NAS boxes at 2 different places and the same flaky issue happens when I access via readycloud app. If disabling iPv6 fixes it, then netgear should look into fixingthe IPv6 issue, correct?
